Crete or Magnum?
Discussion in 'Questions From New Drivers' started by Poacher, Oct 15, 2019.
  1. Poacher
    Poacher Medium Load Member
    338
    280
    Feb 8, 2013
    Looking to change companies and these are the two I'm looking at. I like magnums equipment but want to stay away from reefer. I like that Crete is dry van but not too high on the equipment.
    Any insight on which way would be the best way to go and why.
    Thank you.
  3. bryan21384
    bryan21384 Road Train Member
    15,744
    34,319
    Sep 18, 2009
    Memphis, TN
    I can't speak for either because I've never worked for either. I had talked to Magnum in the past and if things go south where I am at now, they would be an option. They definitely sound good to work for. I thought if you went to Crete then you would pull both dry van and reefer
  4. xlsdraw
    xlsdraw Road Train Member
    4,234
    8,795
    Nov 17, 2010
    Lake Alfred, Florida
    Why choose between two companies you don't want to work for? Research FCC.
    runningman0661 and Poacher Thank this.
  5. bryan21384
    15,744
    34,319
    Sep 18, 2009
    Memphis, TN
    Lol that would be a good ice breaker for an advertisement
    sevenmph and xlsdraw Thank this.
  6. xlsdraw
    4,234
    8,795
    Nov 17, 2010
    Crete and Shaffer are separate divisions. He could try to start up a conversation with SSB. He has worked for both Crete and Magnum.
    bryan21384 Thanks this.
  7. bryan21384
    15,744
    34,319
    Sep 18, 2009
    Memphis, TN
    I only thought they hauled whatever because I see Shaffer pulling Crete and vice versa pretty regularly.
  8. xlsdraw
    4,234
    8,795
    Nov 17, 2010
    It would be funny if FCC adopted that slogan.
  9. xlsdraw
    4,234
    8,795
    Nov 17, 2010
    The truck assignments don't reflect which division a driver works for. At this point, what's on the tractor means nothing. Available driver and available tractor just get married up.
    Farmerbob1 and bryan21384 Thank this.
  10. bryan21384
    15,744
    34,319
    Sep 18, 2009
    Memphis, TN
    Hell yeah...I could see it on one of those recruiting cards in the truck stop
  11. xlsdraw
    4,234
    8,795
    Nov 17, 2010
    The OP is probably researching FCC and SSB. Fremont Contract Carriers and Supersnackbar.
