Crooked dock placement
Discussion in 'Experienced Truckers' Advice' started by robdabest3000, Jul 3, 2019.
  1. robdabest3000
    robdabest3000 Bobtail Member
    15
    10
    Sep 9, 2018
    What's up guys just looking for some advise on how to correct this. I have been driving for about 14 months still considered a rookie by most people's standards. Anyways my question. I have noticed the trailer is always crooked just a couple of degrees typically on my driver's side. Is this just an illusion as I'm seeing closer on my driver's side bc when I pull up to correct myself and go a little the other way to make it perfectly straight I do the same crooked ### back I did the first time. Line or no line on the dock don't matter. Never had any receivers or shippers say anything about it or to move and straighten it. Also noticed a lot of other drivers do the same or more crooked to the dock. I'm just always trying to improve my driving or docking doesn't help that I'm driving for a mega carrier with a name we do not say lol. So I'm naturally under more scrutiny than most.
  3. Moosetek13
    Moosetek13 Road Train Member
    14,984
    19,036
    Nov 1, 2010
    Burnsville, MN
    Try to park it crooked and you should be fine.
    It's all a perspective thing.
  4. robdabest3000
    15
    10
    Sep 9, 2018
  5. gentleroger
    gentleroger Road Train Member
    7,895
    21,600
    Jun 1, 2010
    Try setting ypur mirrors out a little more, particularly the passanger side. Most guys have them set un tpo much, and it gives a skewed sense of perspective.
    Once in the dock crooked, adjust the mirrors so you can see thr same from inside the truck.
  6. robdabest3000
    15
    10
    Sep 9, 2018
    Thank you I haven't thought of that. I will give it a shot.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Could also be the trailer dog tracks. I’ve see some where the pins that lock the tandems are sloppy, going forward they may line up right, going backwards they allow the tandems to head off in a slightly different direction. Not common though.
    stwik, stuckinthemud, MACK E-6 and 3 others Thank this.
  8. robdabest3000
    15
    10
    Sep 9, 2018
    If that was the case then of the hundreds of trailers I've had they'd all be busted lol. No I've had a couple where they were off hella but always dropped and hooked to another.
  9. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,945
    3,315
    Jun 10, 2019
    It depends on what mirror you're using to line up the trailer. If I use the driver side I'm always off a few degrees. If I line up with the passenger side I nail it.
    If it's a few degrees off it doesn't matter. If they can safely unload the #### thing just go about your business. You're not being paid for perfection. Just don't hit anyone or anything, arrive on time, be nice and drive.
    tscottme, x1Heavy and NavigatorWife Thank this.
  10. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    just make sure dock plate and lock arm are good. who cares if its not perfect
  11. 201
    201 Road Train Member
    12,782
    26,305
    Apr 16, 2014
    high plains colorado
    Might be using the mirrors too much. I'd open the door and look to see if I was square. Really no biggie, I figured, if they could get the plate in, good enough.
    truckdriver31 Thanks this.
