cruise control/engine brake not working - volvo
Discussion in 'Experienced Truckers' Advice' started by soon2betrucking, Sep 19, 2008.
  1. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    Did it work in the past?
  3. antony2222
    antony2222 Bobtail Member
    6
    Yeah. Cruise control for highway, and then for high-idle when I'm parked
  4. PackRatTDI
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    The cruise setting at idle is the PTO. Might be a fault in the PTO sytem. Any codes present?
  5. antony2222
    6
    IF you know, how exactly would the PTO manage high idle? You're saying its wired through my hydraulic pump/system? And Im checking for codes right now.
  6. PackRatTDI
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    That's just how the ECM is wired. It's programmed to bump the idle speed and disable the shutdown when you hit resume on the cruise for using a PTO sytem, even if none is actually present.
    For some reason yours is disabled, either by a fault in the system or its somehow been turned off.
  7. PackRatTDI
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    Does the resume work on the cruise control when you're on the road?
  8. antony2222
    6
    Yeah, cruise control works perfectly fine when Im on the road.
  9. PackRatTDI
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    You might have to have it hooked up to a computer to see if the system has somehow been disabled.
  10. antony2222
    6
    Thanks for the help, I appreciate it. I'll have it looked at.
  11. PackRatTDI
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    No problem. I love Volvo Trucks but they can be electrical headaches. My 2015 was in the shop for almost 3 weeks to fix a complete dashboard power loss. They literally had to test every circuit.
    I've had the road cruise not work but the idle up PTO worked just fine. Never experienced the opposite lol.
