cruise control/engine brake not working - volvo
Discussion in 'Experienced Truckers' Advice' started by soon2betrucking, Sep 19, 2008.
  1. antony2222
    antony2222 Bobtail Member
    6
    Haha well it happens to everyone. I just recently replaced my speed sensor. Boy did that thing mess around with my cruise control
  3. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    Did that occur around the time the idle control went out?
  4. Sh00terMcNasty
    Sh00terMcNasty Bobtail Member
    5
    Hi there everyone quick question, if i had the speed sensor unplugged so that i was able to bypass the whole 5mph driver lockout crap. Would my engine brake still be able to function properly when going down a steep grade fully loaded? In a 2014 d13volvo
  5. HellboundStill
    HellboundStill Bobtail Member
    This is a reply to the no idling question. Just turn your cruise switch to on and bump it up one time. Should do the trick.
  6. HellboundStill
    Depends I had the same issues with a Volvo there was two places you can unplug the speed sensor. 1 is up above the batteries and the second one from the transmission. If I remember right it seems like it would work if I unplugged it from one but wouldn't work if I unplug it from the other spot.
  7. Schöne
    Schöne Bobtail Member
    47
    20
    Feb 23, 2019
    Volvo VNL 430. Had ECU and harness connector replaced. Now my jake brake won't work. Any idea what to do? Mechanic trying to figure what to do.
