Cruise control engine break both quit together
Discussion in 'Freightliner Forum' started by Rasim, Dec 31, 2017.
  1. Rasim
    Rasim Light Load Member
    96
    16
    Jan 24, 2014
    k om drivin from stl to rockfiord il in -6 temp weather. Made my delivery and went back home as i was cruisin down the highway all of a sudden my cruise control quit. I tapped the switch and it worked for 10 seconds then died again. Did that a couple of times until it tottaly died. Read online about this issue until someone said somrthing i dont remember he mentioned engine break i flipped the engine break and it stopped working too. Truck is a 98 fld n14
  3. Rasim
    96
    16
    Jan 24, 2014
    I did have a faulty speedometer sometimes the needle would jump up and down and act crazy....but now the needle is dead too
  4. Rasim
    96
    16
    Jan 24, 2014
    Maybe my speed sensor ? Is cruise and jakes connected with it?
  5. Rasim
    96
    16
    Jan 24, 2014
    Now when i lift the clutch paddle it works but have to pull it hard hurts my foot
  6. bigkev1115
    bigkev1115 Road Train Member
    2,364
    3,618
    Oct 23, 2009
    Alexandria, AL
    Its your clutch switch going bad
  7. kemosabi49
    10,992
    47,987
    Jan 13, 2013
    SW Arkansas
    Yes. Check out the switch on your clutch pedal. You may be able to adjust something. If not, replace the switch. Easy fix.
  8. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Sometimes you can just bend the switch contact down a bit if the spring is getting weak, not rocket science.
  9. Majestic 670
    Majestic 670 Heavy Load Member
    908
    809
    May 10, 2016
    Landcruiser
    When it’s parked push pedal in with hand and see if you hear switch
  10. Rasim
    96
    16
    Jan 24, 2014
    It was the switch it shifted a bit
