Cruise control problems...
Discussion in 'International Forum' started by Dom Tugade, Nov 9, 2013.
  1. Dom Tugade
    Dom Tugade Bobtail Member
    5
    Hi,i have a 2007 9400i eagle with isx engine.My cruise control stops working and sometimes it decide to work once in a while.I checked the switch in the clutch pedal and it was good[engine brakes work fine].Where else should i look.If i can find whats wrong i could probably fix.But pls help me diagnose it.....TY
  3. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    That "berger button" you checked on the clutch pedal...there is also one on the brake pedal. Make sure both are tight and functioning properly. That is a big problem with that specific truck (I too have experienced it).
    Some times it will work, but then a bump would knock the truck out of cruise. The button should be depressed with pedals in 'non-use' position...then when you step on the clutch or brake, the button should be completely extended.
    double yellow Thanks this.
  4. Dom Tugade
    5
    White Dog,i appreciate your help Buddy! I tried to look for the one in the brakes but to no avail.Can you help me locate it Buddy....I think thats the one causing it.The switch in the clutch seems to setting on the engine brakes...ty
  5. White Dog
    3,161
    3,807
    Feb 11, 2008
    Iowa
    In front of the arm that connects the foot pad to the firewall or bottom of the dash plate (if I remember right).
    Should look like this: [​IMG]
  6. Dom Tugade
    5
    Thanks Bud!I will try to look for it again....
  7. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Inspect the wire harness that runs from the right side firewall, along the top the engine, to the ECM. This harness has your cruise control wiring in it. This harness likes to rub through on the firewall, rocker cover, or the brackets along the left side of the engine.
    CellNet and double yellow Thank this.
  8. White Dog
    3,161
    3,807
    Feb 11, 2008
    Iowa
    Very good point!
  9. slav
    slav Bobtail Member
    24
    19
    Dec 28, 2012
    There's easy fix. What I did is duct taped piece of cardboard to the clutch pedal at the place where pedal touches the switch, and cruise control and engine brake are both back to normal. I have Volvo. Its been a while since original post, but I hope it will help someone else.
  10. drdiesel
    drdiesel Bobtail Member
    15
    6
    May 12, 2013
    Earth
    Driver side cab cowel air manifold with air pressure switches should be one with a yellow stripe for ECM service brake signal, these fail and Ecm disengages cruise thinking the brake pedal is depress.
