Cruise control won’t come on
Discussion in 'Ask An Owner Operator' started by Rondunn23, Jan 23, 2022.
  1. Rondunn23
    Rondunn23 Bobtail Member
    Jan 23, 2022
    I have 2020 international that cruise control will not come on. I have taken it to the shop over 10 times and still the same issue. Before it would come on and never come back on. Now it won’t come on at all. What should I do?
    77fib77 Thanks this.
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    use the accelerator pedal..???
    seriously though, maybe it could be a bad brake light switch, bad clutch pedal switch (if not an automatic), could be a blown fuse or bad relay, so check the fuses, relays, check to see if your brakes lights stay on, make sure you clutch pedal is not hanging lower than normal (if you have a clutch pedal)
    i'm outta ideas on what else to check.
  4. LoneRanger
    LoneRanger Road Train Member
    3,701
    9,627
    Jun 3, 2018
    There’s a way to bypass the ecm if I’m not mistaken.
    turn cruise on and off 3 times and keep it on on the 4 time.
    it should let you bypass the active braking and radar devices.
    search YouTube as well for ways to bypass the stupid sensors.
  5. Opus
    132,564
    turn off your windshield wipers
    buddyd157 Thanks this.
  6. tscottme
    tscottme Road Train Member
    If your truck is a manual tranny, make sure the clutch pedal isn't sagging. Also check to see if the brake pedal is sagging. Try this. With cruise control off, put your foor under the clutch pedal or the brake pedal. With your foot pull the clutch/brake pedal up. Try activating the cruise control.
    Speedy356 Thanks this.
  7. Val_Caldera
    Val_Caldera Road Train Member
    2,569
    7,939
    Apr 2, 2021
    TARHEEL
    SAME Shop??
    If So, WHY?
  8. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,896
    Nov 26, 2020
    On my freightliner when that happens I will tap the brake pedal twice then pull it towards me the reset the switch. Works everytime
  9. rpad139
    rpad139 Heavy Load Member
    893
    566
    Jan 9, 2014
    Nevada
    Press Firmly on the cruise button, apply pressure if needed. I had the same issue. Push hard on cruise button on steering wheel
  10. MTMAUS
    MTMAUS Light Load Member
    263
    218
    Sep 28, 2019
    My automatic, you can't have the exhaust brake on, or cruise won't work. I am sure you have tried this, but other than what has been posted, that's all I can think of. Does the exhaust brake work correctly?
