cummins engine noise
Discussion in 'International Forum' started by bilingbookworm, Jul 10, 2011.
  1. bilingbookworm
    bilingbookworm Bobtail Member
    Willow Springs Il
    Hi all,Hs anybody ever had a cummins m11 engine that when you shut it down it knocks and shakes. Seems like it wants to stay on. Or go back wards. Or is this just normal for this type of engine, Thanks
  3. Heavyd
    Heavyd Road Train Member
    7,830
    6,282
    Feb 4, 2009
    First thing to do is replace the shut down solenoid and valve. There is a shut off valve that is spring loaded. The solenoid pulls the valve open by magnetic field. When you shut the key off power is taken away and the spring pushes the valve back on its seat and cuts off fuel to the engine. After a few years the valve can get gummed up, or the spring weak/breaks. Either way it doesn't cut off the fuel properly and that is why the engine kinda runs on.
    volvodriver01 Thanks this.
  4. sweetcakes
    sweetcakes Bobtail Member
    I've been having the same issue, thanks for the help
