Cummins Fault code 3226.4
Discussion in 'Trucks [ Eighteen Wheelers ]' started by habfleet, Jan 4, 2016.
  1. habfleet
    habfleet Light Load Member
    163
    23
    Feb 5, 2012
    elwood nj
    I have a 2013 Freightliner Cummins ISX fault code outlet NOX sensor. Replaced sensor and module. Still showing active fault code will not clear. Could the doser valve be clogged and or DPF plugged not allowing NOX sensor to read correct pressure . Truck runs fine. 184000miles. Thanks for any help
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Spn 3226 Fmi 4 equals Nox sensor circuit failed low. Says it's either a one off thing, reset and carry on, or if it's persistent then change the Nox sensor. Which you have done. If you didn't clear the codes after installing the new sensor, it should clear itself after three successful starts.
  4. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    I have attempted to clear the codes no luck Driver used truck all day still on. Thats why i,m thinking something is restriced up stream
  5. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    Checked further when I turn the key on I do not hear the pump for the DPF and noticed that the DPF gauge did not move all day
  6. uncleal13
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I was going to suggest maybe some bad wires to the sensor, but yes if the def isn't coming through, that will make the Nox reading go up. But I thought that would be a different code.
  7. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    I'm thinking that the DPF may be plugged due to the facthat there has been no DEF being injected . The driver's hearing is not the best so can't tell how long the DEF pump may not have been working . Just need a little advise before I start replacing parts
  8. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Double check your code and reconfirm the actual NOx sensor that you changed. There are two NOx sensors. They can be confused. The one on the engine itself, after the turbo is actually the "inlet" sensor. It gets confused all the time as being the outlet because it is after the turbo. The true outlet NOx sensor is after the DPF. The inlet and outlet NOx sensors are two completely different part numbers and not interchangeable even though they look identical and will plug into each others location. We have seen this many times, the wrong sensor got changed and the same code is active awards.
    uncleal13 Thanks this.
  9. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    it's the output sensor locate at the just before the stack. HEAVYD do you have any ideas ?
  10. Heavyd
    7,829
    6,280
    Feb 4, 2009
    Did you confirm they installed the correct part number?
  11. habfleet
    163
    23
    Feb 5, 2012
    elwood nj
    Yes it was the right one
