Cummins insite question. Sensor values?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Deezl Smoke, Feb 21, 2026 at 8:54 AM.
  1. Deezl Smoke
    Deezl Smoke Medium Load Member
    534
    351
    Feb 12, 2011
    Hillsboro Oregon
    For those with experience with Cummins insite, does the program list engine sensor optimum values, or just acceptable ranges?
    In other words, on a X-15E series for example, I'd like to find the actual sent value of each sensor, or......whether the sensor just sends info, and the ecm determines whether or not that sensor or module is within range? If it is the ecm, does insite give what the high and low values are supposed to be whether it be in temperature or pressure etc.?
    Of is there another listing somewhere of said info?
  3. Goodysnap
    Goodysnap Road Train Member
    3,762
    9,167
    Jul 12, 2017
    Insite gives the actual value that the ECM is seeing during operation at a given point in time. Be it saved data or live.
    The expected data ranges are found within the service information in QSOL. A lot of that is understanding how each sensor operates and what its purpose is in the operation and performance of the engine.
  4. Deezl Smoke
    534
    351
    Feb 12, 2011
    Hillsboro Oregon
    Thank you for that.
    So can one just sign in to qsol after insite purchase, or is that a separate cost, and if I don't want to update beyond my own engine, do I have to keep paying to be able to login just for my engine?
