Cummins isx 15 cm 2250 Engine Compression brake output #2
Discussion in 'Volvo Forum' started by RoadRanger^^, Feb 16, 2026.
  1. RoadRanger^^
    RoadRanger^^ Medium Load Member
    317
    118
    Apr 17, 2018
    Columbus, OH
    I was wondering if anyone has the same issue as me with the cummins cm2250. My truck has 6 stages of engine brake first three are working and 4,5,6 looks like they don't work. I have check warning on my dash but sometimes it goes away and also, I have noticed sometimes the Jake will work for a moment but mostly it does not. I'm assuming it is either Solenoid or wiring, but I am wondering if anyone knows how I can check if there is any shortage in the wiring from the ECM, which pins to trace?
    Thanks
  3. dosgatos
    dosgatos Medium Load Member
    607
    1,311
    Sep 18, 2012
    Go on quick serve under service, symptom search. A couple of topics for engine brake
  4. D.Tibbitt
    157,229
    What code is it throwing? It should be logged as an inactive fault.. if ur able to hook it up to insite or any code reader
