Cummins Isx 500hp
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 18wheelroller24/7, Jun 30, 2014.
  1. 18wheelroller24/7
    18wheelroller24/7 Bobtail Member
    14
    :biggrin_2553: Have 06 Cummins ISX 500hp. On Volvo 670 13 speed problem is in lov gears engine stalls and locks the speed. If lets say 9 hi I go 55mph and if I hit a little downhil and hold gas all the way to the floor my engine stalls and I can't speed up. I need to take gear out and back in in order to work.
    Other problem,, I have enginebrake 6speed it has no pressure no power at all.
    Showing oil coming out of engine brake harness. Replaced new harness stil same. Oil temperature sometimes hits 242 ℉.
    No ground torque at all.
    Low speeds when I shift and try to speed up it shakes the front dashboard crazy. Idk. It sucks I know.
    Sometimes spills antifreeze on a ground at over tank hose. ..:biggrin_2553:
  3. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Sounds like engine brake is engaging. Unhook it.
    18wheelroller24/7 Thanks this.
  4. GreatWall
    GreatWall Bobtail Member
    May 24, 2014
    Time for a new truck?
  5. BulletProof
    BulletProof Medium Load Member
    503
    322
    Feb 17, 2013
    Alabama
    If I'm reading the first part correctly (it is kinda hard to make out), it sounds like he is hitting the governor in the gears. My truck I had before had a 10 speed and would not go over 60mph in 9th. If I put it on the floor, the engine would "stall out" at around 1800mph in 9th gear and I would have to go to 10th. The sounds kinda like what he might be doing.
    The problem with the engine brake could be caused by the EPG (exhaust pressure governor). I'd just replace it. Relatively cheap and will eliminate that.
    Antifreeze problem could be a bad air compressor putting air into the coolant reservoir.
    Sounds like you (or previous owner) may have neglected a few things.
  6. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Could be a head gasket also.
  7. BulletProof
    503
    322
    Feb 17, 2013
    Alabama
    Indeed it could. I was trying to give the man some hope
  8. 18wheelroller24/7
    14
    Thanks guys it helps a lot I will look forward to replace EPG but one more thing I didn't mention is that turbo boost gauge is late and when it comes to 35 Psi it goes back to 30 and back when I am in a gear and trying to push it to a higher gear.
  9. Duramaxxed
    Duramaxxed Light Load Member
    155
    60
    Jan 2, 2012
    Bourbonnais, IL
    Isx engines don't have a epg. Any engine lights?
  10. Duramaxxed
    155
    60
    Jan 2, 2012
    Bourbonnais, IL
    Change the exhaust gas pressure sensor and terminals. Known for pin fretting. Should have cel on tho.
  11. Durtyda
    Durtyda Bobtail Member
    5
    Oct 22, 2014
    do a pressure test on the cac!! on the right side engine up front.replace the manifold pressure sensor.then on the leftside intake take the manifold boost sensor out.it will be carbon packed.DONOT clean it.REPLACE it.no ?S asked. then smile!! for a bit.your cummins in suffering from carbon packing.enjoy the torque it should be top notch afterwards.thanks dan 2010-386 pete.550 cummins
