Cummins ISX Breathing
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Smellfunny, May 28, 2024.
  1. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Customer has this ISX that he had at another shop and it was mixing oil into the coolant. He had a complete oil cooler from PDI installed and they said they flushed the system but it is still mixing. I told him I could flush the system and see if they just did a poor flush but as I was flushing it this is his blowby out of the oil fill tube. To me this is a little excessive. https://youtube.com/shorts/M0UapctWCIs?si=cXaAYVlvJdUOgfwC
  3. Big Road Skateboard
    7,098
    40,287
    May 2, 2021
    Moisture on the bottom of the filler cap, or the bottom of the blow by tube?
    You could pull the valve cover and know for certain.
    Of course, it's hard to get all the oil out of a cooling system. Usually takes 4 or 5 flushes for me, and those aren't just fill, bring to temp flushes.
  4. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    Yeah. Not sure what kind of flush they did. It usually takes me longer to flush one than it does to replace an oil cooler.
    Big Road Skateboard Thanks this.
  5. Big Road Skateboard
    7,098
    40,287
    May 2, 2021
    Me too
    Smellfunny Thanks this.
  6. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    dawn soap might help.
    JB7 Thanks this.
  7. Lazer
    Lazer Road Train Member
    1,849
    2,983
    Jan 22, 2017
    Cascade powder is what I’ve been told works the best.
  8. Big Road Skateboard
    7,098
    40,287
    May 2, 2021
    I've used powder and liquid cascade. Less possibility for blockage with the liquid.
    No foaming soaps though like dawn
  9. Star Rider
    Star Rider Road Train Member
    1,787
    18,607
    Sep 23, 2019
    If you use cascade powder dissolve it in a container of hot water first, then pour it in.
  10. JB7
    JB7 Road Train Member
    1,018
    1,804
    Dec 13, 2022
    Laurel, MD
  11. Big Road Skateboard
    7,098
    40,287
    May 2, 2021
