I have a wreaked 2007 international with a Cummins isx cm870 non def rated at 475hp . the ecm has been up dated . my ? is I have a 2006 int. with a cm870 isx rated at 450 hp can I take the ecm form the 2007 an put it on the 2006 with out changing the programs? both have 13 speeds not for sure about the rear ends the could not find any tags on the 06. the 07 has low pro 22.5 an the 06 has low pro 24.5. the 07 was getting 5.8 to 6 mpg till I had the ecm updated an was get 7 to 7.1 before it got wreaked . thank you for your help.
