cummins isx (fuel shutoff valve) code (help)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mike001, Oct 10, 2009.
  1. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Thank you for the kind words. Positive feedback like yours means a lot to us here!
  3. Tmaj12k
    Tmaj12k Bobtail Member
    33
    Apr 2, 2013
    Jersey City, NJ
    I’m having the same issue. Truck wasn’t shutting off after I turned the key to the off position. I only replaced the solenoid itself. I cleaned the parts inside and used new seals. Truck still doing the same thing. I have a couple of questions. First, does it matter that I replaced my solenoid with an aftermarket brand Interstate McBee? Second, do I need replace all of the internal parts as well? Lastly, is there a reset procedure after installation? Does the code need to be reset for the fix to be complete or should the new solenoid work right away?
  4. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    I replaced only the solenoid and it worked fine immediately. I bought mine at MHC, though.
  5. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Might have a bad injector. Need to see if you are getting compression in fuel.
  6. ulenie
    ulenie Medium Load Member
    319
    198
    May 24, 2018
    Houston, TX
    Was the code you getting 1925?
  7. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    That was a while back, I dont remember the code. Truck didn't shut off immediately with the key, though. You can do the solenoid yourself and it's a cheap fix, if that's your problem.
    ulenie Thanks this.
  8. ulenie
    319
    198
    May 24, 2018
    Houston, TX
    I see. No I was looking to buy a truck and it has that code. Thanks
  9. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    1925 is an after treatment (emissions) fault
  10. ulenie
    319
    198
    May 24, 2018
    Houston, TX
    Ya the description for the code is:
    Aftertreatment Fuel Shutoff Valve 1 - Data Erratic,
    Intermittent, or Incorrect. An error has been detected in
    the aftertreatment fuel shutoff valve or the aftertreatment
    fuel injector system. –
