cummins isx (fuel shutoff valve) code (help)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mike001, Oct 10, 2009.
  1. shergill7
    shergill7 Bobtail Member
    Hello i got cummins isx 2008 kenworth, it cranks but not start , fuel pump is working.it seems something stoping engine to start up after crank , any help
  3. shergill7
    I got cummins isx 2008 kenworth, it cranks but not starting, i hear fuel pump is working. Any electrical issue?
  4. Truckers Report Jobs
  5. Heavyd
    Heavyd Road Train Member
    7,810
    6,262
    Feb 4, 2009
    If you can hear the little electric primer pump at key on, that at least means the engine computer is working and booting up at key on. Most electrical issues will cause a check engine light. Make sure at key on there is power at your shut down solenoid. Check for fuel, change your fuel filters because it sounds like a fuel issue.
    pushbroom and spsauerland Thank this.
  6. BigRaul
    BigRaul Bobtail Member
    Heavyd 2022 seems like I found the problem to why it takes my truck a few seconds to shut off after I turn the key to off position
  7. BigRaul
    @Heavyd thanks homeboy I'll be try to fix this selinoid
  8. Outlanderkid
    Outlanderkid Bobtail Member
