Cummins isx oil pan
Discussion in 'Trucks [ Eighteen Wheelers ]' started by PowerPullin, Apr 4, 2015.
  1. PowerPullin
    PowerPullin Light Load Member
    72
    6
    Dec 20, 2014
    PA
    I need a new oil pan for my 02 isx. The aftermarket one I plan on buying says 9 gallon capacity, but when I look up the OEM pan on Cummins site it says 10 to 12 gallon. The brand on the new one is Akmi. Anyone know if it will be OK??
  3. Thed302
    Thed302 Light Load Member
    114
    70
    Oct 30, 2014
    USA
    As long as you don't mind the gallon difference, it should be fine if everything is a direct fit. Call the company and make sure that there will be no fitment issues.
    PowerPullin Thanks this.
  4. FunkRider
    FunkRider Light Load Member
    87
    29
    Jul 22, 2009
    Hamilton, Ontario
    Interesting. I wonder if maybe cummins makes a few different oil pans based on application and the aftermarket pan is designed to cover all of the applications and the oil capacity suffers. One thing you can do with both pans off is put a measured amount of liquid in each and see if there really is a capacity difference. I've never seen the bottom end of an ISX but you can also measure how much you can overfill a pan based on how low the crank and rods hang. The downside to less oil capacity is shorter life between oil changes with less oil volume to hold dirt.
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    With that kind of a decrease in volume, not only would I be worried about soot loading and change interval, but higher oil temps while running.
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    On the Cummins site, 10 is to the low mark, 12 is to the full mark on the dipstick. That is the oil change capacity that includes the oil filter.
    I'd call them to make sure that is correct and ask if they include the gallon in the filter like Cummins does. If 9 is the minimum without the filter, then it'll be the same size as the Cummins one. The filter & filter head holds about a gallon.
    PowerPullin and Cetane+ Thank this.
  7. PowerPullin
    72
    6
    Dec 20, 2014
    PA
    I will look into that. Thanks
  8. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    Probably has the rear sump removed, I wouldn't be worried about it.
  9. PowerPullin
    72
    6
    Dec 20, 2014
    PA
    OK I went ahead and ordered it.
  10. Ridgeline
    22,794
    125,122
    Why?
    Just go with the original.
