Cummins ISX oil problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by superhill56, Dec 13, 2017.
  1. superhill56
    superhill56 Light Load Member
    216
    94
    Jul 28, 2016
    Powdersville, SC
    I have an 06 Volvo with a Cummins ISX. My oil pressure has been running on the low end (about 20 idle/30ish running). I only had to add 1 gallon of oil every 15,000 miles. I got my oil changed on 11/14. I drove about 400 miles last night and by the top I stopped my running oil pressure was at about 28/29 psi. I started back home 400 miles and got about 70 miles away and my low pressure warning came on and I checked oil and was down 2 gallons. Added the oil and it went back up to 30ish. I have driven 5,500 miles since the oil change. I took it to a mechanic and he said I needed inframe (didn't look at it just taking a hunch). Mainly because there wasn't anywhere he could visibly see where the oil was going. He said it was probably coming out my stack and to look and see if I had a shiny black gloss on my trailer where the stack is. I looked and didn't. Is there anything else it could be that could be causing my issue or is inframe only solution and do I have anyway in finding out? My engine has 820,000 miles on it so I knew it was coming but I was hoping to get a little more out of it. It's sucks bc it's been running like a charm. Sorry so long and thanks for all input!!
  3. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    The oil has to go some where. Did you check the coolant? Are there any leaks?
  4. superhill56
    216
    94
    Jul 28, 2016
    Powdersville, SC
    No oil in the coolant. I checked my oil this morning and it was over full so instead of being down a gallon I was probably down a little over a gallon.
  5. W9onTime
    W9onTime Heavy Load Member
    710
    1,354
    Oct 6, 2017
    What oil do or did you use ?
  6. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    When the oil was changed, was the same brand and weight used?
  7. superhill56
    216
    94
    Jul 28, 2016
    Powdersville, SC
    I have always used Rotella. To tell you the truth I'm not 100 percent on the oil now I'm getting engine chatter so I'm thinking my engine might be done. Crap this sucks.
  8. W9onTime
    710
    1,354
    Oct 6, 2017
    best of luck driver
  9. superhill56
    216
    94
    Jul 28, 2016
    Powdersville, SC
    It was a pulley that was making the noise wheewwww still keeping check on the oil.
  10. W9onTime
    710
    1,354
    Oct 6, 2017
    If you were only using a gal of oil in 15000 miles , your cylinder kits seem tight , might get away with just doing bottom end bearings , oil pressure seems low to me mine runs about 25 or so at idle warm , and 35 at road speed warm , I have a 2006 cummins with over a million miles and mine uses about 1 gal of oil in 15 k as well .
    Watching your thread and wishing you luck
  11. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    I just had mine rebuilt back in june at idle my oil pressure runs at 15psi and cruising down the highway its at 33psi.
