cummins isx problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by amanb, May 30, 2010.
  1. amanb
    amanb Bobtail Member
    vancouver, bc
    i've got a cummins isx 500 in my truck with almost 350, 000 km on it..........last friday, i shut my truck off and went to get coffee and when i came back, i tried to start it and made weird noises and white smoke came out..........no problems before that.......ne hints as to wot it could b
    the noise it makes when i turn the key is like TUC-TUC-TUC-TUC-TUC
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Check your coolant level and report back if it's low and how much.
  4. dmg1029
    dmg1029 Light Load Member
    182
    55
    Jun 6, 2009
    Coeur d Alene, ID
    he didn't say what year motor? Good call on coolant level. Someone told me they (2008 and above) are very sensitive to coolant usage.
  5. amanb
    vancouver, bc
    The truck is 2005 and i've checked the cooland and the engine oil levels..........all are good.
  6. Diesel Dave
    9,687
    32,974
    Jan 20, 2010
    Hesperia, Ca.
    Sounds like an injector starting to go out. Did you get the check engine light on ?
  7. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    ISX's are very finicky about fuel filters. There are two of them. I had this happen with an ISX that started blowing white smoke and acting up before and the primary filter needed changed. No codes. It seems to happen all of a sudden, like yours, without warning. At least it would be a cheap try to change a fuel filter and see if that solves the issue.
  8. amanb
    vancouver, bc
    yeah the check engine light came on in the morning and then i went away after a while..........but when the problem happened, came back on
  9. mrdevildog
    mrdevildog Light Load Member
    75
    22
    Feb 23, 2010
    Heber Springs, Arkansas
    id start with seeing what the code was first, you could try changing fuel filters but isx has a fule pressure sensor that with set active fault codes if the fuel pressure ets to low, it might have set a "951" fault code for cyclinder imbalance which could mean a number of things, but untill you know for sure what code was set active everthing
    i've said is my opion.
