Cummins ISX Running Hot
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Mike379L, Jul 28, 2014.
  1. Mike379L
    Mike379L Bobtail Member
    9
    Aug 27, 2012
    Humboldt, Sask, Canada
    Have a 2000 freightliner century class with the isx Cummins. I've been having issues with it running hotter then it should be. I'm hoping some one can give me some advice on where to look next. With the fan on auto it will run upwards of 230f or more. Hot enough that the warning light will come on. If I run with the fan on manual, it will get up to 215 max. Which I think is a normal temp(correct me if I'm wrong).
    Truck info,
    Farm truck pulling tridem grain trailer mainly. Not long distances, so a lot of shifting up and down. loaded gvw is 47,500kgs(104,000lbs).
    What I've tried,
    Replaced coolant filter(several times), thermostats, water pump.
    Done coolant system flushes, and cleaned the rad. The rad is clean and fresh coolant in the truck with proper mix.
    I'm not sure where else to look. any help, will be much appreciated!
  3. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Try replacing the coolant temp sensor. Since the warning light is also coming on, the gauge is reading correcting, but the sensor could be measuring falsely.
    Nostalgic and Mike379L Thank this.
  4. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
  5. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    215 is normal when climbing a hill, but typical temps cruising on flat ground are 170-190. If 215 is normal, then there is a problem.
    Mike379L Thanks this.
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    You can pull the grill out and unbolt the charge air cooler, then look how much dirt has stuck to the inside of it and rad. then clean it out good.
  7. Dee1915
    Dee1915 Bobtail Member
    6
    Apr 24, 2011
    Mike379L,
    I agree with all the suggestions given.
    If you don't have to pull any long hills you will likely be able to get by running with the fan on on overide until the weather cools off.
    When you say the rad is clean do you mean it was done by a Rad shop or with a garden hose?
    If the other suggestions don't fix your problem and its already been to the the Rad shop you will likely have to replace the rad core.
    I had a lot of problems with my T600 rad cores using the green antifreeze.
    Rad shop cleaning didn't last very long.
    When I switched to long life antifreeze the rad cores lasted a lot longer.
  8. Mike379L
    9
    Aug 27, 2012
    thanks for the suggestions everyone! Im going to look further into how clean the rad is. From what I can see it is clean, but maybe I haven't done a good enough job on that. Also going to change the temp sensor. fairly cheap and easy thing to try. Thanks again!
  9. khalidjamal123
    khalidjamal123 Bobtail Member
    32
    5
    May 15, 2016
    Did you ever figure out what the problem was with your truck? I have a Volvo with a ISX with the same issue.
  10. CAV289
    CAV289 Bobtail Member
    Did any of you ever figure out what the problem was I,ve got a 2005 International 9200 doing the same thing.
