Cummins ISX15 never ending check engine lights
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by javelinjeff, Apr 30, 2019.
  1. Goodysnap
    Goodysnap Road Train Member
    3,775
    9,202
    Jul 12, 2017
    I would not suspect an electrical issue with the faults you have provided. Was the fuel injector reset performed in Insite when the injectors were replaced? Has a injector performance test been run with pass results? Has the rail decay been checked?
    The only other issue is a return restriction back to the tanks on the injector return. This may test good in the shop bay as it seems like you always have issues on the road and running under load for a while.
    javelinjeff and pushbroom Thank this.
  3. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    What are the miles on engine right now?
    My guess is your over 500,000 miles?
    The CM2250 is notorious for dropping number 5, or 6 cylinder liner from carbon build up.
    What do you mean bottom end was gone over , when fuel pump blew?
    Many times with a cm2250 when the fuel pump blows the engine needs an inflame.
  4. pushbroom
    pushbroom Road Train Member
    1,791
    7,403
    Sep 1, 2012
    His current fuel issues have nothing to do with a dropped liner. Completely different.
    spsauerland Thanks this.
  5. javelinjeff
    javelinjeff Medium Load Member
    621
    185
    Aug 30, 2007
    victorville,ca
    That was replaced in march
  6. javelinjeff
    621
    185
    Aug 30, 2007
    victorville,ca
    These tests were done after injectors were replaced and problems were still showing. Checked for air in fuel also, when they tried to do the last injector performance test, he kept getting a 1911 fuel restriction code, pressure relief valve was tested- pass, tanks, lines, filters were checked or replaced, like I said in the beginning, they are scratching their heads or their peanuts trying to figure it out. It is the big shop along the freeway near the Pilot truckstop in Hesperia CA, a very reputable shop
  7. Goodysnap
    3,775
    9,202
    Jul 12, 2017
    I would suggest installing a gauge on the drain line from the injector leak back to check for pressure.
    Was there any rail decay?
  8. javelinjeff
    621
    185
    Aug 30, 2007
    victorville,ca
    They said there was no fuel decay, if that's what you mean, hoping to get a load back near the house to let them dig a little more. Also have an open ticket with Cummins Tech Support. They are wanting an Insite to be hooked up to truck and driven untill fault returns
  9. javelinjeff
    621
    185
    Aug 30, 2007
    victorville,ca
    Also, after truck is cleared of codes, it will run strong, then it will hesitate or go dead pedal for a second or two, sometimes up to 5 seconds, which temporarily triggers yellow light on tach. This will also happen when cruise control is being used which rules out TPS
  10. javelinjeff
    621
    185
    Aug 30, 2007
    victorville,ca
    Update, transfer pump replaced, fuel pressure relief valve changed, fuel pressure sensor replaced, fuel lines replaced, injectors are being removed for inspection. Cummins Tier 3 Diagnostic technician at a loss as to why truck continues to have erratic fuel pressure. Truck has had test pump head installed in place of new, truck has had test ECM used to rule out ECM, truck has been run on isolated fuel source to rule out supply issues from tanks. It is getting to the point of having to remove radiator cap and replacing truck underneath it. I feel that the biggest part of the problem is the lack of concern by Cummins to isolate and resolve the problem at their expense. I have spent over 16k on this issue that remains unsolved, and all the repairs on this truck have been performed by licensed/ certified Cummins repair facilities.
