Cummins L10 330
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ronh504, Feb 21, 2019.
  1. ronh504
    ronh504 Bobtail Member
    11
    Feb 21, 2019
    Question for you guys. I have a 1993 International Dump Truck with a Cummins L10 330. I was told it had 400k on it when l brought. Truck runs good but I would like to put a little more fuel to it. I called the Cummins dealer since it has a ECM on it it was told that it had a mechanical fuel pump on it. From my novice I looking at it I can't see where it's mechanical. Am I missing something and can be the fuel be turned up for just have to be programmed in the ECM.
    Thanks for any help.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    If it does not have a rod or a cable to the fuel pump it is not mechanical. Does it have a wiring harness going to the injectors?
    Dino soar and spsauerland Thank this.
  4. ronh504
    11
    Feb 21, 2019
    No red, no cable. The accelerator has a sensor under the pedal. As far as the injectors, I would assume they have a wiring harness but not near the truck and never paid any attention.
  5. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Pics? Do they have the same style fuel system as the big cams?
  6. ronh504
    11
    Feb 21, 2019
    Well back home now and did I little research. The motor tag reads L10 330E. From what I can see the stands for electronic fuel pump. Why is the Cummins dealer telling me they can't turn the fuel up? They just don't want to fool with it i guess.
  7. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Epa and liability
  8. Humblepie
    Humblepie Pontificator
    5,077
    80,318
    Dec 25, 2018
    Cummins won’t go past what the max hp from the factory is. The L10 didn’t go up much if any from 330. And I doubt there in much in the aftermarket world for that motor as it was replaced 25 years ago by the m11. They were good motors just weren’t a hoss.
  9. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    A shop that specializes in injection pumps might tweak it for you. Install a pyro if u don't have one
  10. Humblepie
    5,077
    80,318
    Dec 25, 2018
    If I remember right it’s a hermorphidite engine. The pump is mechanical with electronic controls. It’s neen a while since I’ve worked on one
  11. ronh504
    11
    Feb 21, 2019
    So to get more pulling power out of it is not possible? I dont need anything top end, just would like a little more on the bottom end.
    Or just wait for it to run its life out and upgrade.
    Humblepie Thanks this.
