cummins lift pump will not run HELP???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by terryt, Feb 15, 2012.
  1. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    The engine will run without the lift pump, but you have to crank it like crazy to get it started, mine leaked when it failed.
  3. Dino1968
    Dino1968 Light Load Member
    Must depend on the engine, one of mine will,albeit will sputter if pulling hard[ that's the one that tried to burn itself up], other one died and wouldn't start till lift pump was replaced.
  4. terryt
    terryt Heavy Load Member
    736
    777
    Apr 27, 2009
    This pump is only 8 months old "the one I took off". The old orginal red pump started leaking last June 2011. I really do not think the ISX is a bad engine have many freinds with the accert cat that have many more issues and cost far more to repair. They are getting 5.8 MPG. My ISX will out pull them and still get 6.5 mpg with 80000lbs 7.5mpg light load all day. I'm very happy with this engine never used a drop oil between 20000 oil changes. Oh well thanks again for your help.
  5. 9express
    9express Bobtail Member
    26
    6
    May 4, 2014
    kissimmee Fl
    wow that's good to know i am getting hard starts i cant figure out why
  6. Dstn
    Dstn Bobtail Member
    I have a ISX15 CM871 in a 2010 Prostar, the pump hasn't worked in probably 8 months. The engine starts right up every single time. After an oil change and fuel filter change it takes about 10 seconds with no manual priming and has only sputtered one time after a fuel filter change. Interesting how the same engine in a different truck can have a hard time and the other has no problem without an operable pump.
  7. Heavyd
    Heavyd Road Train Member
    7,831
    6,282
    Feb 4, 2009
    Original first release ISX engines didn't come with a primer pump at all and were added by recall kits. The main pump is ok to draw fuel, but just causes an "extended" crank in most cases and very rare to cause a no start. They aren't critically needed, they are mostly to help start the engine a bit quicker.
  8. Tonycrete
    Tonycrete Bobtail Member
    Jul 5, 2018
    I have a truck doing the same thing , the fuse was blown , we changed it , the pump will run , but it gets very hot to the touch and it will still not start
  9. Tonycrete
    Jul 5, 2018
    I have a truck which is doing the same , the fuse was blown , we replaced it but still will not start, the pump is getting very hot to the touch , is there a way to see if it is pumping
  10. Heavyd
    7,831
    6,282
    Feb 4, 2009
    Take the fuel filter off and key on. If it works, fuel will run out.
    Jazz1 Thanks this.
  11. Tonycrete
    Jul 5, 2018
    Changed pump , cycled a few times , fired right up
    Heavyd Thanks this.
