Cummins m11 fan
Discussion in 'Trucks [ Eighteen Wheelers ]' started by earthmover, Nov 3, 2016.
  1. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    1997 freightliner fld cummins 11 my fan is air clutch and I have a manual switch..problem I'm having is the fan now comes on and off at random even just driving empty . .this is a dump truck ..where at what should I be looking for . .where would the sensor that control the on off be on the motor..I know I have 1 in the surge tank but I think that's for low coolant . .also I see the air control valve by the clutch could that be going bad ..thanks
  3. AModelCat
    164,921
    Usually the fan on most engines is controlled by coolant temp or A/C high side pressure. Could be an issue with the sensors/switches and associated wiring. Could also be a short or wiring issue related to the manual switch.
  4. earthmover
    563
    20
    Jan 27, 2009
    Ok I was having problems with the ac kicking off and on right at the end of the summer ..is that the same switch ..
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Maybe: Does it have a four wire switch on top of the dryer? That is an all in one called a trinary switch. What are your a/c pressures running. About 275-325 on high side should cause engine fan to come on. Does it do it with a/c and defroster turned off?
  6. wrenchman
    wrenchman Bobtail Member
    16
    7
    Nov 4, 2016
    Also, I have run into where Flr ran there control for the fan on the M11s on the front RH side of the engine and the wiring will chaff and short and command the fan on/off when least expected and very inconsistantly, something to look at. Take care, good luck.
  7. earthmover
    563
    20
    Jan 27, 2009
    No it has 2 wire plug on top of it..
  8. earthmover
    563
    20
    Jan 27, 2009
    I check wiring from fan back didn't find anything . .
  9. earthmover
    563
    20
    Jan 27, 2009
    Looks like I have to switches on the dryer ..
  10. earthmover
    563
    20
    Jan 27, 2009
    You guys think 1 of the switches on the dryer could be the problem
  11. BoxCarKidd
    4,551
    6,641
    Aug 26, 2014
    yes but check it out or have it checked out. Don't just swap parts.
