cummins n14-370e cranks only
Discussion in 'Trucks [ Eighteen Wheelers ]' started by clhart426, Mar 21, 2012.
  1. clhart426
    clhart426 Bobtail Member
    43
    Dec 15, 2011
    Toledo,OH
    Dealing with a volvo. Turn key on, stop engine and engune fluids lights turn on, but do not shut off. Engine only cranks. Ran into this problem at the end of fall last year, but as it got colder it started to work. Now thats its hot weather again, not working. Any ideas? Maybe temp sensor or something??
  3. ohio_redneck75
    ohio_redneck75 Light Load Member
    128
    51
    Sep 27, 2010
    coshocton,ohio
  4. clhart426
    43
    Dec 15, 2011
    Toledo,OH
    Would a ground allow it to crank but not start? I thought if the ground was good enough for cranking itd be "good ground". Ill throw a new cable on it, it is pretty flexible and weathered. Thanks for reply!
  5. clhart426
    43
    Dec 15, 2011
    Toledo,OH
    Ground was not it. Pulled dog house from truck and found a "distribution" area where i think battery cables tie into ecm power? Found some corrosiin, repaired them. Still same problem. Will crank but no start. Warning lights stay in..
  6. Smellfunny
    Smellfunny Road Train Member
    1,446
    969
    Jan 28, 2012
    South Carolina
    Do you have fire at fuel solenoid?
  7. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Drainback valve ... check and make sure you have fuel in fuel filter.
  8. clhart426
    43
    Dec 15, 2011
    Toledo,OH
    No power at solenoid when the two lights do not shut off. Jumping power to it didnt allow ut to start either. This morning i turned the key, self check happened, lights turned off and fired right up. Very confusing, thats why i thought temp. At first
  9. blanco
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Are ur tanks full or empty when it happens?
  10. clhart426
    43
    Dec 15, 2011
    Toledo,OH
    Theyre about 1/4 right now.
  11. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    Have you pulled the ECM harness plugs and checked them for moisture/corrosion/damaged connectors?
