Cummins N14 flywheel differences
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by thesvg, Feb 5, 2021.
  1. thesvg
    thesvg Light Load Member
    192
    13
    Dec 9, 2010
    Hello all. I need to replace my clutch on my celect+ and I see three different part numbers for a flywheel: 3609903, 3609890 and 3609903R
    Is there a variance on these three? I cant re use my current flywheel because the previous owner before my last clutch swap six years ago used a smaller clutch that gouged the FW out of spec.
    Rideandrepair and Bean Jr. Thank this.
  3. Rideandrepair
    17,575
    56,937
    Aug 8, 2015
    I’d check Dealer if you can’t find the answer. Your vin # will tell original build. If your lucky they’ll give you a part #. Maybe ask for an estimate for Clutch job, if you have to. Estimate should show all part #s needed. I’m sure they’ll flywheel is $1600. I bought one on Amazon. $240. Lot of aftermarkets out there. Just as good as Dealers. Mines done a good job.
    pushbroom Thanks this.
  4. pushbroom
    pushbroom Road Train Member
    1,791
    7,403
    Sep 1, 2012
    Whats the s/n
    Rideandrepair Thanks this.
  5. thesvg
    192
    13
    Dec 9, 2010
    Hello, all. Thanks for the replies. I called cummins Southern plains and they said 3609903 and 2309903R have a removable ring gear. Found one at a salvage yard. Because it was $3200+ shipping for a new one.
  6. thesvg
    192
    13
    Dec 9, 2010
    I got the 15.5 clutch at dealer. Wonder what part no is the smaller one.
  7. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Fleetpride had flywheels on sale last month for 135.00. I bought a stack of them for different engines.
    jsnell Thanks this.
