Cummins N14 fuel pump leakimg?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by thesvg, Oct 17, 2017.
  1. thesvg
    thesvg Light Load Member
    192
    13
    Dec 9, 2010
    20171017_122800.jpg Hey all!
    Has anyone ever encountered a fuel leak in their N14 fuel pump by the filter housing?
    At first I thought it was the com fitting, but after taking it off and placing a plug, the fuel leak still persistent.
    It only leaks while it's cold, cranking, and a few seconds after it warms up. No leaks when it's warm, and running. [​IMG]
    Fuel puddles up on top of the filter, but the housing above it gets wet. Here's a pic
  3. Heavyd
    Heavyd Road Train Member
    7,839
    6,295
    Feb 4, 2009
    Probably leaking from between the housings, orings dried out, shrunk.
    thesvg Thanks this.
  4. thesvg
    192
    13
    Dec 9, 2010
    Is this serviceable? Just unbolt, and replace o-rings?
  5. Heavyd
    7,839
    6,295
    Feb 4, 2009
    I am sure it is. It's been a while. That section between the filter base and engine block is the pulsation dampener. It could be leaking too, and also has a sandwich of plates and orings. We don't see too many N14 anymore, and I can't even remember the last time I changed a fuel pump for one. If this pump is original or been there for a while, I would replace the whole pump as it is probably worn and tired anyway.
    Justrucking2 Thanks this.
  6. boneebone
    boneebone Road Train Member
    2,298
    2,374
    Mar 13, 2009
    If it's leaking when it's cold, it's because the o-rings have contracted and is letting fuel seep through.
    When it's running, the engine heat plus the fuel is expanding the seals preventing fuel from leaking out.
    I would remove it and replace the o-rings and it should be fine.
