Cummins NTC 444 proper overhead procedure
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 704mover, Nov 15, 2021.
  1. 704mover
    704mover Light Load Member
    60
    22
    Mar 8, 2018
    My engine is a 1989 NTC-444, CPL 1210. Is the OBC method with injectors set at 90 inch/lbs & valves at .11&.23 my best bet? I've tried the IBC with injectors at 5 inch/lbs & .14&.27 before in years past too. I'm replacing head gaskets and putting in rebuilt injectors so I'd like to set it up right. Just wandering what method and settings most are using on this finicky STC to get it running like it ought to. The data plate on the side of my engine does say valves set at .11&.23.
    Thanks
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I like the OBC method. Always make sure there is no oil pressure in the system.
  4. 704mover
    60
    22
    Mar 8, 2018
    So injectors are set at 90 inch/lbs using the OBC correct? It's been a while for me
  5. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    Certain cpl's set the injectors at 105 in/lb. That always felt too tight so we used 90. The valves
    are set at .014 &.027. The .011 & .023 specs are used when setting up inner base. Pay attention
    to the plastic oil jumper tubes that sit below the injector. The plugs can blow out & cause an
    oil leak & the injectors won't go to advanced time. If they're original i'd replace them.
    BoxCarKidd and 704mover Thank this.
  6. Inderjit
    Inderjit Heavy Load Member
    770
    735
    Sep 17, 2017
    If I remember correctly there are seven moving part stacked in the injector.
    As the injectors wear the injector travel gets to be less. The outer base
    circle method was meant to address that, as using the inner base circle
    method on worn injectors camshaft and injector train would be overloaded.
    With new injectors both methods will work fine.
