Cummins SC vs. BC1 vs. BC3 compression ratios
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Jul 16, 2023.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,419
    1,739
    Dec 4, 2019
    Wondering how the compression ratios changed over the generations of these engines? Let’s just use the 350 and 400, in each generation to compare.
    Though I’m curious about the series 4 engines, I believe they’re fuel delivery system(ST) may have impacted their compression even more?
  3. SmallPackage
    5,827
    18,679
    Dec 20, 2019
    Marion Texas
    My 1951. Nh743/220 is 15:1.
    1972. Nh855/250 is 14:1
    1974. NTC855/350 is 13:1
    mile marker 27 Thanks this.
  4. W923
    W923 Road Train Member
    1,429
    4,428
    Feb 28, 2022
    I don’t know that the compression ratio followed the series of the engine as much as it did the hp
    Generally speaking the higher hp the lower the compression ratio. Probably a few exceptions.
  5. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    When I rebuilt my engine I looked at what pistons were available. I couldn't get the 15:1 pistons for CPL 1280/1256. The 15:1 that were available didn't have cutouts for a high lift cam
    14.0:1 3050480, 3053500, 3048808
    14.5:1 3045948
    15.0:1 3048809
    15.5:1 3052794, 3050366
    17.0:1 3069212, 3053526,3095064
    There may be others but those were the most common
  6. SmallPackage
    5,827
    18,679
    Dec 20, 2019
    Marion Texas
    One thing I can tell you is the ratios didn't really drop until the NTC’s because of turbo’s. Then they dropped a little more with the after cooled models and slowly came back up a little with some of the BC’s. With it’s high compression the old 743 cid NH220 had probably the best sound and had a race car idle at 500 rpm if tuned right. The 855 cid NH250 was the best sounding 855 ever. Also the loudest straight stacked Cummins besides the two and six bits supercharged NHRS with back drop manifold. Both were normal aspirated.
  7. S.truck
    S.truck Bobtail Member
    What piston did you decide on? I’m about to tear into a 1256
  8. RocketScott
    579
    949
    Apr 10, 2013
    Kentucky
    I used 15.5:1 pistons from PAI. Not completely sure that was the best option or not. That's what capitol reman was going to use when I first talked to them
    Another guy sent me an ESN for a rebuilt 444 and they used 14:1 pistons. They changed a bunch of other things too so I don't really know how to compare. I had already rebuilt mine at that point also. Wasn't going to go back and change everything
    Field Fix 155 uprated the NTC-444 to NTC-450 but I never did find documentation on what that change involved
