Cummins x15 knock
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mercer6890, Dec 11, 2024.
  1. Mercer6890
    Mercer6890 Bobtail Member
    Good Morning all
    I have a 2019 Kenworth T800 with a Cummins X15. The engine has a knock when under load at about 1400 to 1500 rpms. To me it’s sounds like a fuel knock from a bad injector. Put it in the kenworth dealership shop they suggested an overhead and changed out DPF sensors, and the knock is still there. My question is how do I identify which cylinder has the knock because I’m sure it’s a fuel related knock only the mechanics at this shop can’t figure it out.
  3. Big Road Skateboard
    7,098
    40,288
    May 2, 2021
    Cylinder cutout will isolate it to cylinder, but doesn't necessarily mean it's a fuel knock.
    Isolate the cylinder, then look for valve train/jake issues first. If you find nothing and pull the injector, check what you can of the cylinder walls and piston before throwing an injector in
  4. Mercer6890
    Ok thanks, an overhead has been run, I’ll talk with the mechanic shortly to see what checks he’s performed. would be prudent to perform a compression check?
  5. Big Road Skateboard
    7,098
    40,288
    May 2, 2021
    It couldn't hurt, but wouldn't be my main goal. What I described should lead to a diagnosis. If it's a knock, they should have isolated the cylinder first. Sounds like they,'re going in blind.
    Some others here may have more specific X15 info
    @Goodysnap?
  6. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    Cut out is the only way to pinpoint a hole to narrow down. From there swap injectors hole to hole.There is no published compression test for the engine.
    Most knocks or noises can be somewhat misinterpreted. The engine is somewhat noisy to begin with. Some of the gear train noises sound like a bag rocks just setting at a stop light.
    What’s really disappointing is to tear it down and find nothing. Sometimes it’s just better to run it until it gets worse or to failure. That being said, most bottom end issues are on 5 or 6. Broken rings pistons etc.
  7. D.Tibbitt
    157,132
    I always wondered if that bag of rocks sound was normal. The 2350 isx seemed to be the worst with that
    Diesel Dave Thanks this.
  8. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    2350 sound like crap from new
    Diesel Dave and D.Tibbitt Thank this.
  9. ClonkeyDonkeyPhD
    ClonkeyDonkeyPhD Bobtail Member
    6
    Dec 12, 2024
    Inspect your vibration damper at the front of the engine for for signs of seperation between the inner and outer pieces. It's nonserviceable and can only be replaced. I had 1 engine in the shop 2 years ago that I couldn't find the knock. It definitely had one when test drove. I ran overhead after cold-soak, inspected each cylinder with cut-out test. Finally decided to look externally and I removed the belt and inspected front auxilary and engine components. PFP was the Vibration Damper; the rubber isolator deteriated and caused the vibration at mid-ranged RPM's.
  10. Mercer6890
    Thanks all gives me some direction, cylinder cutout not showing anything engine actually idles smooth and sounds quite normal even when rpm’s increased but hook a trailer up and load the engine at 1400 rpm’s it starts knocking I’d hate to run till failure it’s a strong and very efficient engine. I’ll pass on the advice maybe they’ll find it soon.
    Thanks again folks
  11. Diesel Dave
    9,671
    32,754
    Jan 20, 2010
    Hesperia, Ca.
    Throw a gallon of Lucas fuel and see what it does. Or some 2 stroke oil.
