Curious...stainless injector cup verses copper?
Discussion in 'Volvo Forum' started by 6cuda6, Nov 22, 2020.
  1. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    So curious here....do stainless injector cups last longer than copper?
  3. dieseldan6991
    dieseldan6991 Bobtail Member
    Nov 1, 2018
    Generally speaking, in my experience, yes. Stainless steel cups have always seemed to last longer in all applications I've used them in. Had an mp8 that had multiple issues with the brass/copper cups and switched to the stainless steel everything was good.
  4. Dave_in_AZ
    425,769
    I guess my question would be why is there an option if the stainless are that much better?
    Snailexpress and bigguns Thank this.
  5. Numb
    Numb Crusty Curmudgeon
    4,325
    10,279
    Jan 30, 2012
    Charlotte, N.Carolina
    copper is cheaper.
    magoo68 Thanks this.
  6. 6cuda6
    259
    176
    Oct 9, 2020
    Can't be cheap enough to make any worth while difference in the final bill.....
    There has to be a plausible reason if Volvo still sells them both. (Not sure they do but it sure seems like it)
  7. Numb
    4,325
    10,279
    Jan 30, 2012
    had an '08 D-13 that went through 3 sets of injectors. 2 under warranty. don't remember what the cost difference was.
    Volvo tried to get us to replace with stainless, but nooooo, had to go cheap.
  8. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    The best part with copper is that you can replace just the cups and don’t need to replace injectors with stainless you have no choice I would still take the copper if there was a choice much cheaper to fix being that stainless has almost same intervals of failure just cost 3 times as much being that you have to replace injectors as well
    Snailexpress Thanks this.
  9. 6cuda6
    259
    176
    Oct 9, 2020
    Very interesting reply.....being a mechanic i have no issue doing the job and if it saves the injectors thats great!!
    baha Thanks this.
  10. 6cuda6
    259
    176
    Oct 9, 2020
    Can you use the newer style push through tool or is the pull through type better on copper?
    baha Thanks this.
  11. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Copper can only be installed with the pull thru tool never have I tried using the push tool so I couldn’t tell you if usable or no.
    baha Thanks this.
