D O T Question
Discussion in 'Questions From New Drivers' started by Exit310, Feb 19, 2019.
  1. Exit310
    Exit310 Medium Load Member
    537
    244
    Jul 13, 2011
    cullman,alabama
    I work Sunday night through Thursday night & log off Friday morning @ 5AM. & i still have about 20 hours left, can i still drive part-time for another company?
  3. Part time doing what?
    Driving? Yes logbook required
    Painting no logbook required
    Bean Jr. Thanks this.
  4. Moose1958
    Moose1958 Road Train Member
    15,175
    33,419
    Dec 17, 2010
    Williesburg, Virignia
    Yes, you can. There is no rule that says you must only use your driving hours for one carrier. I would only caution about that 60/70 hour clock and make sure you maintain enough time to do the primary job.
    brian991219 and Exit310 Thank this.
  5. Expeditor
    Expeditor Medium Load Member
    451
    530
    Mar 5, 2018
    Yes absolutely, if paid then must log on duty hours, you can work all you want, within State labor laws. You just can't drive if you go over your 14 hr or 70 hr clock without taking a minimum 10 hours sleeper or off duty.
    Edit: he can work all he wants but before he drives he would need a reset.
  6. Moose1958
    15,175
    33,419
    Dec 17, 2010
    NO! You MUST either get recap back to drive once past that 70 OR do a reset. Just doing a 10 is not enough!
  7. Expeditor
    451
    530
    Mar 5, 2018
    You are correct, if he starts Sunday and finishes Friday he has nothing to recap. Reset before he drives.
    Exit310 Thanks this.
  8. Moose1958
    15,175
    33,419
    Dec 17, 2010
    My first comment was written under the possibility the OP was talking about driving. If not that's OK too. Just remember as a professional you should get rest. If you are doing none driving work on the weekends you are not getting good rest. You can do this at 25, but as you start to hit those middle age years it is not as easy. So my answer is yes, absolutely. Just get enough rest!
    brian991219 Thanks this.
  9. Exit310
    537
    244
    Jul 13, 2011
    cullman,alabama
    My bad, i should have said "can i drive" for another company.
    Ruan is hiring part-time drivers on the weekend for the Target account that`s why i asked.
  10. tscottme
    tscottme Road Train Member
    You are still limited to 70 hours in 8 days or 60 hours in 70 days FOR ALL WORK YOU DO FOR **ANY** EMPLOYER. So you could use your remaining 20 hours to be a cashier, driver, test pilot, porn star or any job. It's NOT just driving jobs that count against your HOS.
    wis bang and TripleSix Thank this.
  11. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Corrections:
    • ALL work for any motor carrier counts against 60/7 and 70/8 clocks.
    • COMPENSATED work for non motor carries does as well.
    • There is no limit to the non-driving hours that can be worked whether for motor carriers or not.
    • In order to drive there must be sufficient hours remaining on 60/7 and 70/8 or recap hours or after a reset.
    On-duty time means...
    (8) Performing any other work in the capacity, employ, or service of, a motor carrier; and
    (9) Performing any compensated work for a person who is not a motor carrier.
    - §395.2 Definitions.
    brian991219 and tscottme Thank this.
