D12 check engine
Discussion in 'Volvo Forum' started by Zeeny, Oct 21, 2014.
  1. Zeeny
    Zeeny Light Load Member
    54
    Nov 16, 2013
    Hi was wondering if someone can help me out with this just got a check engine light come on with the fuel pump sign on checked the code and it says it's for fuel feed pressure code is MID128 PID94 FMI7 can anyone guide me on what to do for this thank you for your help
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    too low fuel pressure.
    Failt code is active if fuel pressure is lower 1 BAR.
    I think fuel pump is old and worn. It is not easy to change it yourself, but possible.
    Do not reuse gasket. And do not reuse long M8 bolt.
    You can purchase genue ore aftermarker pump (chenese ore polish), but aftermarket pumps require better fuel filtering, becouse spindel is not so well secured in gear. I have additional Davco fuel filter-separator, so I use aftermarket pumps.
    Some of bolts are difficult to access and u need set of 1/2" and 1/4'' sockets with extentiors.
    before u start, place PET film with some sand under pump area to keep pavement tide.
  4. Zeeny
    54
    Nov 16, 2013
    Where is the fuel pump,that's a brand new motor on that truck,doesn't it come with a new pump,it's a reman motor from Volvo only has 7k miles on it
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    D12 was introduced in 1992 and discontinued in 2006. The last version was D12F for Renault and Mack trucks, but Volvo changed D12D with D13A in 2005, so I think U have D12D (Euro-3 ore EPA2002).
    It cant be new, and I think pump is worn
    It is located in front of engine, dr. side.
    D13 got pump located in rear end of cyl block, becose it has rear geartraine
  6. Zeeny
    54
    Nov 16, 2013
    Oh I know the motor is new haha,I paid 25k for it lol,it's an 07 780 with a d12 D,I reset the code and it has not come on I'm trying to think if I put a new pump with the motor just can't remember , i
