Here we go again, my 99 d12 is acting like it's running out of fuel. Runs good down the road but when I'm shifting it runs out of fuel. I have changed filters, lines from the tank and tee block. Is there a check valve or something else to look for? It dosen't do it all the time and if I pump the primer and bleed the line it will start after several trys. Just seems to do it when thr RPMs go up and down. It's got me stumped!!
D12 fuel trouble
Discussion in 'Volvo Forum' started by hard times, Jul 29, 2011.
Your crossover feed lines that balance your fuel between tanks might be acting up. They can be finicky. Try topping off both fuel tanks.
both tanks are full, thanks
It sounds like you might be airlocking. Did you fill that fuel filter you changed to the top even though you have the pump. That might fix it and it doesn't cost anything to try. If the old filter was bad but you didn't get fully bled by filling the new filter with fuel this could have created an air lock that the pump can't get past.
Yes it's full, the truck may run 20 miles and when I stop and go again it starves for fuel and seems lose it's prime,
And how tight is it?
All of your new connections I would look at. -- You can just about bet that your getting air from one of them or none of this but something entirely different in the first place.
What was it doing from the first symptom on, at the very beginning before you did anything.
That hand pump itself could be leaking. -
it started whenI shut it off and would not start, filled filters and pumped, started and ran good. Got to where when I was shifting up with the rpms up and down it would run out of fuel, I could fill filters and prime and it would run. I thought it was sucking air so I changed lines. Still the same, but now won't run at all. Never had a pump do this but never owned a Volvo, could it be the pump?
I'm guessing that the pump is about a million dollars. I would keep doing everything you been doing over and over again hoping to get lucky and cure it or find the problem or it to just start working without knowing exactly what you did. A few hours a few times.
Then the computer readings. Or the computer readings first if you can afford it but the computer may not show a simple connection or air leak problem. That's why I would exhaust everything first. I'm not sure if you could try a direct fuel line put in your filler opening and to the filter as a bypass that might tell you something. I shudder to think what a fuel injector pump would cost. Especially if you don't need it.
