D12 losing power for a split second
Discussion in 'Volvo Forum' started by dorlia2, Jun 12, 2022.
  1. dorlia2
    dorlia2 Light Load Member
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    06 Volvo with D12 465hp
    Engine is losing power for a split second when loaded. Happens randomly and only when torque is needed. Diagnostics show everything in order, Fuel pressure, Turbo PSI
  3. dorlia2
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    The only thing that seems out of order is ECU battery potential Goes up and down between 10 and 13.9 volts constantly, even when idling
    Battery charging and voltage is steady at 13.9v
  4. poniikyanion
    poniikyanion Light Load Member
    69
    14
    Nov 23, 2009
    Newark, NJ
    You need to check the pair of small wires for the ecm that connect to the battery terminals for tightness. If they are loose you will lost engine power for a moment whenever you hit a bump on the road. I have a 05 and also used to have a 98 that would skip with the loose wires.
  5. dorlia2
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    Looks like potholes do not affect the problem, only higher torque demand does
    Wires look/test good
  6. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,264
    Nov 14, 2021
    ALBERTA
    To get help you may need a better description than just 'losing power'.
    What happens with the RPM? Does it drops? By how much? How long?
    I suggest an instrumented loaded test with a PTT attached that will scan and catch it when it happens.
    I don't recommend a Volvo dealer unless you have no other option.
    The better service you can get from a private shop that works on Volvos like yours.
    Call them, give them your truck VIN, book a test and
    when it's fixed come back here and update the thread.
    As a courtesy and to help other owners with the same issue.
  7. dcc_BTT_Trucker
    dcc_BTT_Trucker Bobtail Member
    7
    5
    Jan 20, 2012
    My problem was the air filter. My empty trailer lot is a dirt parking lot. I have to wait for the dust to settle just to back up. RPMs would randomly drop and a smoke ring would come out of the stack.
  8. dorlia2
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    I am suspecting voltage drop for ECU. Vcads reading shows constant fluctuation between 10 and 13 volts at ECU battery potential. Alternator is good at constant 13.9v
