D12 pre DEF - performance upgrades?
Discussion in 'Volvo Forum' started by newdriver2, Sep 19, 2019.
  1. newdriver2
    newdriver2 Light Load Member
    97
    87
    Sep 14, 2017
    Yes, I have googl'ed.
    07 volvo vnl with the D12 pre DEF (has working EGRS)
    few random questions I have been researching ...
    Turbo upgrades? I know the stock turbo is the HX52... made by volvo. I have seen Holset make a turbo also, are they the same? I've read that the stock HX52 is good up to 750hp and is also used in the Dodge 5.0 cummins.
    I have also read some guys swapping the HX52 with a HX55? I assume there is a ton of turbo lag associated with that...
    question #2 - Does the dealer simply offer just a quick tune? A "Performance" tune or something? Ideally I would like to have the EGR delete done (a tune would be nice just to turn it off an keep them closed) I'm not looking to spend thousands on a tune...it drives an runs fine..
    I'm sure it has been gone over three million times, Yeah I know...its a d12.. I'm not looking to win any races by any means but just curious. I was simply researching to make the truck run a little cooler and have cleaner oil and that is why I started looking an reading all of the different stories from the other drivers on the road.
    anyways :)
    Reason for edit: Wanting info on egr deletes
  3. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    #1 Holset makes the turbos for Volvo.
    #2 Any Volvo dealer will Never install any kind of delete. TTR does not allow members to openly discuss deletes.
    401-Alex Thanks this.
  4. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    FYI most know that the D12 never came with DEF.
