D13 and with i shift, vibration using stage 3 engine brake.
Discussion in 'Volvo Forum' started by 05vnl670, Jul 21, 2018.
  1. 05vnl670
    05vnl670 Light Load Member
    165
    60
    Feb 17, 2013
    Is any one have experienced a vibration when using stage 3 engine brake. I also noticed that when the ECO-ROLL is on when and the truck shifts to neutral costing,I also feel it vibrating. I have 2014 d13 with I shift combo.
  3. Diesel Power
    Diesel Power Bobtail Member
    45
    16
    Nov 1, 2016
    I have same vibration on engine brake stage 3. My mechanic sad that my injectors are going bad. I know it does not sound logic but on stage 3 engine brake, fuell injects in combustion chamber for better braking power
  4. AlBig
    AlBig Light Load Member
    145
    52
    Apr 16, 2017
    When had you done last TuneUp? Mast be done at 150k than every 250-300k
    KB3MMX Thanks this.
  5. 05vnl670
    165
    60
    Feb 17, 2013
    I got the truck not too long ago,but over head was done 30,000 miles ago and injectors replaced about 90,000 ago.
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    That makes no sense you need a new mechanic .. Fuel creates acceleration not deceleration ..
  7. Diesel Power
    45
    16
    Nov 1, 2016
    It does. Injected fuel creates more power energy inside combustion chamber while using engine brake. Do more research on D13 engine.
  8. magoo68
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    It’s the variable geometry turbo that creates more energy braking on stage 3
    Trucking in Tennessee Thanks this.
  9. 05vnl670
    165
    60
    Feb 17, 2013
    To me it feels more like drive train vibration than engine. I also feel very similar vibration when the truck is rolling in ECO- ROLL.
  10. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    Check your u joints and carrier bearings
    magoo68 Thanks this.
  11. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    No no no. The injector pulse is Zero on deceleration.... Zero.
    If fuel is getting in the cylinder, the injector is leaking , etc
