D13 and with i shift, vibration using stage 3 engine brake.
Discussion in 'Volvo Forum' started by 05vnl670, Jul 21, 2018.
  1. Amram
    Amram Medium Load Member
    448
    235
    Feb 4, 2017
    Have the engine brake hydraulic pistons checked. It is a known issue with the d13. The tops come unscrewed. They either have to be tightened back up or replaced with the new revised version.
    KB3MMX and racemaxx24 Thank this.
  3. Jon_z
    Jon_z Bobtail Member
    Feb 22, 2019
    Did you get the problem fixed? We are having the same issues with a 2013 Volvo. Noticed that the vibrations only happen when the turbo preasure reaches about 28 psi in brake position 3 on ours.
    KB3MMX Thanks this.
  4. Trucker2211
    Trucker2211 Light Load Member
    94
    91
    Mar 3, 2015
    Also having same issue with 2015 D13. Stage 1 & 2 engine brake work fine, but on stage 3 it starts vibrating/pulsating so bad I’m waiting for something to fly up thru the hood so I try to avoid using it. Started doing this after truck’s first overhead was done about 100k ago. Odometer is showing 455k now.
    So it’s the engine brake’s pistons that need adjusted or replaced? I have never heard of engine brake pistons. I assumed it was either valvetrain or injector/cup problem.
  5. racemaxx24
    racemaxx24 Heavy Load Member
    718
    922
    Jul 4, 2014
    East TN
    Dealer ended up doing a repair similar to what Amram described in the post responding to me, and it fixed the issue for the rest of the time I had the truck. However the driver that has it now claims it is vibrating again, although I haven’t verified if it is the same vibration and intensity.
    But for the record, my 2019 with 10k miles has started the significant vibration on position 3 engine brake already. Although it’s not consistent, only does it about 20% of engine brake applications. Must be a common issue
  6. Jon_z
    Feb 22, 2019
    I went to the dealer and they ended up replacing the turbo and doing an overhead adjustment but it didn’t change the vibration at all. I asked about the redesigned engine brake pistons but they said you have to buy a whole new rocker arm. Did you happen to have a part number for what they replaced?
  7. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    My 2018 does it, but only occasionally. I figured it was just the price you have to pay to drive the best class 8 CMV ever.
  8. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    Sounds like the engine brake isn't firing on all cylinders like when you run a X15 Cummins engine brake on low... it shakes cause it's not Activating all 6 cyl.
    Overhead is the very first place i would look to repair!
    x1Heavy and Newto Trucking Thank this.
  9. mortal_oean
    mortal_oean Bobtail Member
    39
    Sep 13, 2014
    2014 volvo d13 ,10 speed,500hp
    Started doing the exact same thing
    Engine brakes, 1and 2 ok but 3 starts shaking. Pretty bad .
    please keep it going so we can have some idea where to start the reapairs from. may be some mechanic from somewhere may come up with some idea of what to do .
  10. 1Doughboy
    1Doughboy Bobtail Member
    Jan 29, 2012
    Exhaust Brake Plungers are Backing out...Have any Volvo shop check them and Readjust... It’s not actually part of doing an “Overhead” so it gets overlooked... Essentially Your engine brake starts “missing” creating a vibration under max engine brake..
  11. 86scotty
    86scotty Road Train Member
    4,728
    12,991
    Aug 27, 2017
    Appalachia
    Yep, I just did this too. A $500 overhead and they found one that was badly out. All good now.
    KB3MMX, mortal_oean and Newto Trucking Thank this.
