D13 bad mpg and less power
Discussion in 'Volvo Forum' started by Katsarov, Nov 16, 2017.
  1. Katsarov
    Katsarov Bobtail Member
    8
    4
    Jun 30, 2013
    Hi, I have a 2012 d13 with ishift. It was averaging 6.8 to 7 mpg and had very strong pull. Now 6.4 and I have to keep trans on "P" a lot more often. No codes, no intake leaks, new injectors and cups, new boost and nox sensors. New sensor on the ventury pipe ( do not know the name. No effect.
    Please, guys, help. Truck is just under 500 000 miles
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    What part of the country.?
    Winter fuel could do it.
  4. Mooovover
    Mooovover Bobtail Member
    Oct 30, 2017
    Not trying to insult your intelligence or anything after all you listed that was new and checked out but sometimes the obvious most simplest thing can get you, have you checked your air filter.
    KB3MMX Thanks this.
  5. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    about due for dpf cleaning, for one, the second is did you check how the air to air system is make sure there is no boost leaking specially at the clamps on the right side the pipe between cac and turbo, also check charge air cooler make sure nothing is leaking.
    KB3MMX and olddog_newtricks Thank this.
  6. dismag
    dismag Bobtail Member
    37
    Jul 20, 2012
    what do you mean saying "keep trans on "P" a lot more often"? It is bad habit to switch gear selector to P while you driving. You will damage transmition eventually.
    Socal Xpress Thanks this.
  7. uncleal13
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I think he meant Performance mode. If your transmission has that option as opposed to standard or economy mode.
    KB3MMX Thanks this.
  8. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    No check lights? I had this problem and it went to derate mode. I think it was the Def fluid sensor harness corrosion common problem.
    KB3MMX Thanks this.
  9. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
  10. dismag
    37
    Jul 20, 2012
    Sorry I figure it out. I
  11. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
