D13 DTC code help, getting code SA 16 DTC
Discussion in 'Volvo Forum' started by lbeach180, Feb 5, 2019.
  1. lbeach180
    lbeach180 Bobtail Member
    14
    Nov 22, 2017
    2015 Volvo d13
    I’m getting a pretty vague engine code “SA 16 DTC - - -” anyone have any insight?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Push button for more info / next page
  4. lbeach180
    14
    Nov 22, 2017
    Already tried. Shows page 1/1 only.
    uncleal13 Thanks this.
  5. uncleal13
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    After DTC it should show a number. Just a fantom code otherwise.
    Things seem to be running okay?
  6. lbeach180
    14
    Nov 22, 2017
    That’s what I was guessing. Thanks for your input. Yeah I just got the truck so not to many miles on it yet but so far so good!
  7. Lovepreetbrar
    Lovepreetbrar Bobtail Member
    Hi , I got the same issue .check engine light is on and it shows only SA 16 dtc only . Did you got it fixed ! What was the issue !
  8. Sergii001
    Sergii001 Bobtail Member
    I have the same problem did you find out what problem is?
  9. uncleal13
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    SA 16 is the engine.
  10. Lovepreetbrar
    Yes,it was showing multiple error with stc 16 code .issue was with the eco roll switch .as it’s a electrical issue I would suggest you to get it fixed from them dealer that will cost less to you .i tried going to various shops before reaching out dealership and none of them was able to track a real problem and I ended up paying money to every shop .
