I been having problems with this truck for the last 2 months so I take it to the dealer they replaced my egr cooler and egr valve get on the road the following week same problem so volvo replaced it a week later same problem now it’s back at the shop and they said it’s the egr cooler and egr valve again they did a further investigation and the found nothing.... has anybody else had this problem or know what it could be because I’m ready to do the do with this egr and say f it my truck got 603033 miles it’s a 2013 Volvo D13
D13 egr problems
Discussion in 'Volvo Forum' started by Tcainmayne, Feb 13, 2019.
Page 1 of 3
Do you the fault code logged ?
Spn 94 fmi 18
Spn 1127 fmi 10
Spn 1127 fmi 14
Spn 1127 fmi 18 -
I will have to check in my own note at work. but i remember when the 1127 ls active there is no egr flow. let me come back to you with an anwer.
KB3MMX and Socal Xpress Thank this. -
Note When the code 1127 is active there is no reading of egr flow or egr temp in the Lap top Most of the time that code is generate by a major leak of turbo boost pressure for a long period. Let me know your find. Please. Ben
Yeah they just called and said they found a airbubble in my coolant system but idk if that’s when they just replaced it or from the first time they did it
Î’m not sure if i inderstand you ?
They found A air bubble in my coolant tank i don’t know if that was because they just replaced the egr cooler or the air bubble was in my lines when they just replaced it
I see. Look for a large boost pressure leak between turbo and engine intake manifold.
Page 1 of 3
