D13 Fuel Problem (HEAD SCRATCHER)
Discussion in 'Volvo Forum' started by nasriza, Jan 13, 2017.
  1. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Already checked and replaced fuel filter assy
  3. cumminskid123
    cumminskid123 Light Load Member
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    When you bypassed the supply, did you hook up to the fuel ports on the tank, or did you just put the hose in the filler hole? Possibly a cracked stand-pipe? Could have bad fuel? water, algae, gelling issues in the cold... Possibly a cylinder head issue but that would be my last choice, it seems like you've covered most of your bases, no codes? only happens when cold? Post back with results and observations please
  4. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Check the update post
  5. Tcainmayne
    Tcainmayne Light Load Member
    55
    11
    Dec 20, 2018
    Hey did you ever find your problem my truck is doing the exact same thing and can’t figure it out replaced egr valve and egr cooler and nothing fixed it so can you tell me what was the fix
  6. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    So my problem was fuel issue. This truck had separator on fuel filter housing and at some point someone decided to put cigars in the tanks which blocked ecm cooler so I took off all fuel hoses and started blowing them out till I removed restriction and it was good
    NWAF, Sun-e d t and Newto Trucking Thank this.
  7. Dave_in_AZ
    428,611
    I have a question ( Raises hand ).
    So what was the bill for this?
  8. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    if you include the parts that were changed at the customers request because he was trying to rush me to get truck running as soon as possible, ( when he finally gave up pushing was the day i figured it out)
    So injectors 4000
    fuel filter housing 500
    drain all fuel dispose send out tanks for cleaning and reassemble. 1400
    clean all fuel lines blow out everything and reassemble. 450
    my headaches of having to mess with this for 2 weeks till i figured it out even when volvo couldn't. Priceless.
  9. VictorTr
    VictorTr Bobtail Member
    6
    [QUOTE = "nasriza, post: 8228249, member: 106797"] Итак, моя проблема была в топливе. У этого грузовика был сепаратор на корпусе топливного фильтра, и в какой-то момент кто-то решил положить сигары в баки, которые заблокировали охладитель ECM, поэтому я снял все топливные шланги и начал их продувать, пока не снял ограничение, и это было хорошо [/ QUOTE]
    good evening!! Do you do repairs ? I have the same problem .
  10. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    yes i have a shop in west chicago il
  11. VictorTr
    6
    [QUOTE = "nasriza, post: 11303196, member: 106797"] да, у меня есть магазин на западе Чикаго, иль [/ QUOTE]
    How long does it take to call you to make an appointment when I am in Chicago
