D13 over heat when going over 70mph
Discussion in 'Volvo Forum' started by mike0321, Jul 18, 2018.
  1. mike0321
    mike0321 Bobtail Member
    28
    4
    Jul 9, 2018
    I've got 2012 Volvo D13 I got problem with coolant high temperature I already spent too much money change radiator water pump EGR injector cups twice tested for combusion gases because before I change injector cups was building some pressure in the cooling system Now doesn't build pressure and still overheating problem exists actuallyactually the problem exist when I start driving over 65 miles an hour even empty like I mentioned before I change almost everything anybody have the the same problem in the past an advice please help me because I have no clue what's going on please help me if you can
  3. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    Take the winter front off
    KB3MMX and Oldironfan Thank this.
  4. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    You ever flush the radiator and change coolant yet?
    KB3MMX Thanks this.
  5. Snoopycda
    Snoopycda Medium Load Member
    361
    715
    Jan 22, 2016
    Edmonton Ab.
    Drive at 60 mph?
    How many RPM are you spinning at those speeds, maybe the truck is not spec'd out for that speed.
    KB3MMX and pmdriver Thank this.
  6. mike0321
    28
    4
    Jul 9, 2018
    1550 rpm by the way 6 months ago everything was fine
  7. mike0321
    28
    4
    Jul 9, 2018
    Like I said three weeks ago I put brand new radiator
  8. mike0321
    28
    4
    Jul 9, 2018
  9. pmdriver
    2,338
    3,503
    Nov 14, 2017
    get yourself one of those digital thermometers and start searching for hot spots, and sometimes they close the heater core off to cut heat in the cab, cutting amount of fluid cycling.
  10. mike0321
    28
    4
    Jul 9, 2018
    I got one can you describe where is the heater core exactly located ?
  11. Snoopycda
    361
    715
    Jan 22, 2016
    Edmonton Ab.
    What model of Volvo do you have?
    Follow the two heater hose that go into the firewall, the heater core will be there.
