D16 exhaust smell?
Discussion in 'Volvo Forum' started by 6cuda6, Mar 23, 2021.
  1. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Anyone ever run into an exhaust smell from the front of a d16? I'm thinking EGR cross over pipe gaskets but can't pin point it...i can smell if when i stand beside the frame rails mainly front right side of the motor/fan [little less on the left side] area but physically cant see anything a miss.
    The exhaust fumes are getting into the cab with hood closed and its avoiding my detection....yes it has a new flex pipe, yes it has a new EGR cooler, yes it has a new DPF gasket.....even if they all had tiny leaks it wouldn't equate to the exhaust smell coming into the cab.
  3. Espey127
    Espey127 Bobtail Member
    49
    11
    Dec 13, 2016
    Check for soot around turbo. You should see the normal amounts of rust, then black soot. Recently had to replace gasket on my D13 for extract same issue.
    6cuda6 Thanks this.
  4. 6cuda6
    259
    176
    Oct 9, 2020
    I'll give it a look....thanks for the reply:)
  5. 86scotty
    86scotty Road Train Member
    4,728
    12,991
    Aug 27, 2017
    Appalachia
    What year and mileage? Just curious for comparison.
  6. 6cuda6
    259
    176
    Oct 9, 2020
    2008 and about 1.1 mil
  7. 86scotty
    4,728
    12,991
    Aug 27, 2017
    Appalachia
    Man, I would consider moving on from that truck if you can, when you can. I have never heard good things about 07/08 Volvos or any year D16.
  8. 6cuda6
    259
    176
    Oct 9, 2020
    Its actually for a none commercial project and is never going to haul a trailer again....honestly it problably will outlast me for what its going to do next. The D16 is not the best engine in the world and over kill for the project but for the price i payed and being a mechanic, i can afford to pit a few hours into it.
    86scotty Thanks this.
  9. Espey127
    49
    11
    Dec 13, 2016
    Did you find the leak?
  10. 6cuda6
    259
    176
    Oct 9, 2020
    Havent had the chance to look as its been pissing rain here for 2 days straight......weather is supposed to clear today so ill get a look finally.
  11. 6cuda6
    259
    176
    Oct 9, 2020
    Ok your close.....in this case EGR valve gasket were it mounts to the manifold and possibly the rear most exhaust manifold gasket but i would have to remove the dog house to get a really good look at it [not sure if its oil residue or soot at this point].
    Thanks for the info, caught it finally in a picture with my phone trying to take a photo of the bottom of the turbo mount.
