dac?
Discussion in 'Questions From New Drivers' started by p.moore, Jun 18, 2015.
  1. p.moore
    p.moore Bobtail Member
    4
    Does anyone know if fedex checks your dac before or after you get to orientation .
  3. hunted
    hunted Medium Load Member
    Not sure I thought Fed Ex only has owner ops. In my area there are no company Fed Ex drivers. The owner ops do the hiring for their trucks. And im sure they aren't using hire right services
  4. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
    Although I cannot speak for FedEx Ground, nor FedEx, I can say that a long time ago, I worked for the now defunct RPS which was company/and o/o's. To work there, as a company driver, I can assure you that a full background check was done on me, including finger printing.>!! and this was all long before TSA..!!
    RPS was sold to FedEx, which they split into FedEx Ground, which are o/o's and some company drivers.
    So I could only surmise, FULL background checks are done, as I am somewhat certain they fall under the US Postal rules/codes like my old employer DHL did, and man, did I get a background check from them..!!
    But like some companies, they can check a DAC at any time, before hire, or in orientation, even during your employment with them.
  5. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    It depends on what flavor of FedEx you are talking about. There’s FedEx Express, FedEx Ground, FedEx Custom Critical, and FedEx Freight. Some divisions are all O/O and others have company drivers.
    hunted Thanks this.
  6. 2Girls_1Truck
    2Girls_1Truck Medium Load Member
    513
    640
    May 18, 2014
    Nova Scotia, Canada
    Whether or not they use HireRight, they most likely do reference checks and anything on a DAC is probably not going to be under wraps for long.
    If I were you, I know I'd rather try to explain whatever it is than have a monkey on my back, worrying I could be found out and fired at any time for failing to disclose it.
