Daisy chain explained please?
Discussion in 'Freightliner Forum' started by Hulld, Oct 17, 2017.
  1. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    I would like to add a boost gauge to my 2007 Columbia and would like to know if I could use a factory gauge and how the daisy chain set up works?
    Also what parts would I need?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    They sell add on boost gauge kits a pitt. power, but its just a gauge with a plastic line leading from intake to gauge, easy to install if you found a gauge at the junk yard and bought some line to hook it up nothing ele. is is needed
    Hulld Thanks this.
  4. Pedigreed Bulldog
    7,737
    14,423
    May 7, 2011
    Perhaps jumper a power and ground wire over to the gauge to light it up with the rest of the gauges, but other than the gauge, airline, and fittings to connect to the intake, you don't need anything else. Mechanical gauges are nice like that...
    Hulld Thanks this.
  5. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    easiest way is to buy a Scangauge D. You will have boost gauge and many others to. Setap is 5 minute , no additional wires, sensors,....
    Hulld Thanks this.
  6. Hulld
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Thanks for the responses.
    I have extensive experience with both electric and mechanical boost gauge set ups on my blower car and turbo snowmobile.
    What I am researching is information on a factory freightliner boost gauge that hooks up via the freightliner daisy chain platform ?
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Daisy chain: one set of wires operates all of the gauges.
    I believe on a Cascadia it starts at the tach, then the speedometer, then in series to all the other gauges all in a row, one after the other. You are free to re-arrange the gauges any way you wish, they are all computer coded and only pickup the information they are particularly looking for out of that set of wires. Only some of the air gauges work independently.
    The very last gauge on the line may have a terminating resistor plugged in after it.
    brian991219, mhyn and Hulld Thank this.
  8. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    If there is a spot for it, it will probably plug in. They just read the data off the bus.
    @mhyn ... the scan gauge on my Cat-powered Columbia only goes to 31.5 lbs of boost and then stops. I know for a fact the max boost is almost 50 lbs because I also have a mechanical gauge on it.
  9. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    You should be able to find the wiring schematics somewhere, beats guessing. I have mine for the ProStar.
  10. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Daisy chain simply means that all your gauges are hooked to the data link. All of your gauges have 2 plugs, in/out. The wiring simply jumps from gauge to gauge so they are all connected on the same wires. It does not matter what order they are wired, they all get their signal from the same data link. To add a factory gauge, you need to find the last one in the "daisy chain" (the one with only 1 plug) and run a jumper to the new gauge. Then you need someone with the ServiceLink software to activate it in the SAM module for it to work. Some gauges would require a sending unit added (common with trans or rear temps, pyro's, etc.) and wired to the SAM. But a boost gauge would use the boost pressure sensor that the ECM already uses. The SAM would just need to be programmed to transmit that data to the gauge.
    brian991219, mhyn, SAR and 2 others Thank this.
  11. Hulld
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Thank you!
    This is exactly what I was looking for.
    Do you know if a 2007 Columbia uses the daisy chain platform ?
