Damage from sidekit stakes?
Discussion in 'Flatbed Trucking Forum' started by Zwiser, Nov 26, 2018.
  1. Zwiser
    Zwiser Bobtail Member
    14
    14
    Aug 23, 2017
    Hey all, is the anyway to prevent the stakes from making holes on the side beam on trailers? Ive used the stakes that have the collars around the bottom but the collars eventually wear out and sink into the stake pocket...
    any advice is appreciated, I just got a new to me trailer and I dont want it to get all holed up!!
    Thanks!
    Zach
    x1Heavy Thanks this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    The only stakes Ive used were with the Ravens and those are extruded rods that went in a certain way. Once in, all you had then was to put up the foam side panels between them. There was no loading or securement to those.
    If your trailer's pockets are getting weaker with load leaning on stakes that aint broken yet, I get confused and need pictures if at all possible from your phone about the situation in particular before I can understand you better. You can transfer the image to paint, save to desk top and then upload direct to here.
  4. Zwiser
    14
    14
    Aug 23, 2017
    Yeah ok I dont have any pics at the moment but ill grab some in a couple days and post them up.
    Thanks
    baha Thanks this.
  5. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,654
    Oct 5, 2012
    Earth
    Steel sidekit? Have you considered wood?
  6. Zwiser
    14
    14
    Aug 23, 2017
    The aluminum side kit stakes wear a "T" into the side of the beam above the stake pocket.
    OLDSKOOLERnWV Thanks this.
  7. Tb0n3
    4,738
    9,654
    Oct 5, 2012
    Earth
    Have you considered fabing up a bushing for that area? Fill in with rubber or wood?
  8. Fatboy42
    Fatboy42 Light Load Member
    281
    389
    Feb 9, 2011
    Indiana
    You can go to an industrial plastics dealer and get thin abrasion resistant material cut into small pieces and afix to trailer with bonding adhesive the hole thing is about 1/8 thick the plastic guys will know what will work best to put under stake.
    PoleCrusher, OLDSKOOLERnWV and Tb0n3 Thank this.
  9. OLDSKOOLERnWV
    19,156
    289,682
    My trailer originally had a sidekit, and has the usual "T" marks worn into it. Unless you attach a wear plate of some kind, it will wear unfortunately.
    PoleCrusher Thanks this.
  10. OLDSKOOLERnWV
    19,156
    289,682
    You thinking of something like Mylar? It is good stuff, and is used as a skid / wear plate in many applications. And it can be bent / shaped to a certain form, just by heating with a torch till it's nearly transparent. I have made "L" shaped wear plates with 3/8" thick material before.
    bigguns and PoleCrusher Thank this.
  11. jamespmack
    216,602
    What kinda trailer? My 1996 has marks from them but no holes!. Or get a well fitted tarp to allow less movement?
