Dash actuator
Discussion in 'International Forum' started by Crysa1989, Jun 13, 2022.
  1. Crysa1989
    Crysa1989 Bobtail Member
    Hello I have a 2000 international 9900i I changed both actuators underneath the passenger seat. I am looking for the one in the dash. The defrost works and if I change settings it still comes out thru the defroster vents. If u can help that would be greatly appreciated. Thanks
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Sounds like you have a blend door in the heater box broken or otherwise screwed up. My KW’s have done it a few times. If you changed the actuator and it still isn’t working right I’d suspect a blend door problem inside the heater box. Haven’t fixed one on a farm implement before so I can’t guide you beyond that.
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Should be behind the panel that is between the speedo/tach and main switch panel. In behind is a removable piece of duct and the actuator should be there.
