1. Douglas Powell
    Douglas Powell Bobtail Member
    New Brunswick Canada
    2008 ISX-CM871 15L…2.2 million kms.. code came up on dash stating “ Exhaust Gas/Temp 2… followed by blue heavy smelly smoke..what now.???
  3. Goodysnap
    Goodysnap Road Train Member
    3,833
    9,382
    Jul 12, 2017
    I would take a close look into the DPF fuel doser. Leak and flow check it for starters. Excessive fuel entering the exaust can cause higher than normal DPF inlet temps which could cause the fault as well as the hot/ smoke due to the higher than normal temps.
    Otherwise get hooked up and check faults and troubleshoot accordingly. If it still has the old doser with the bolt on heat shield, best replace it anyhow.
    spsauerland Thanks this.
