Dash lights
Discussion in 'Freightliner Forum' started by blazer_72, Jul 17, 2020.
  1. blazer_72
    blazer_72 Bobtail Member
    20
    4
    Nov 18, 2015
    Louisiana
    I have a 2003 freightliner Coronado the tachometer and speedometer are lighting up but all the other gauge lights do not work any suggestions?
  3. RocketyMan
    RocketyMan Medium Load Member
    554
    337
    Jun 5, 2015
    Last 6 of vin? Need to know what cluster you have. Could be daisy chain problem most likely, aka, wiring problem with sat gauges.
  4. blazer_72
    20
    4
    Nov 18, 2015
    Louisiana
  5. RocketyMan
    554
    337
    Jun 5, 2015
    Alrighty..you have an ICU2M. Have you tried checking the bulbs specifically? THey are made to be replaceable whit exception of the lightbar that has LEDs on some of them.
  6. blazer_72
    20
    4
    Nov 18, 2015
    Louisiana
    No I figured with so many out it had to be something else.
  7. RocketyMan
    554
    337
    Jun 5, 2015
    So from this schematic, there are 12 quantity of circle-11, which is a lamp-wedge based.
    BTW...you should have the lamp removal tool designated as circle-13 for this purpose.
    QUALITYTRUCK Thanks this.
  8. blazer_72
    20
    4
    Nov 18, 2015
    Louisiana
    Ok thanks I'll check it out
